If I wanted to rewrite the Heimdall DAQ Firmware and perform my own phase synchronisation between the channels, how would I go about triggering the noise source on and off?
I found the following line in rtl_dac.c;
rtlsdr_set_bias_tee_gpio(rtl_rec->dev, 0, 1);
Does this control the noise source? Otherwise would it be possible to explain the primitive to control this?
Cheers!
