can i use the lan port of the raspberry pi to access the DOA?
Plan is. The kraken gonna be station 2 of them for triangulation. Im having problem with the lan port . It doesn’t give ani ip address the built in wifi is fine .
Yes the ethernet port on the Pi 4 should work just fine. I use it sometimes too.
I’m not sure why it’s not giving you an IP address though. Ethernet is set as the highest priority in the network settings.
If you run ifconfig in a terminal you should see the Ethernet interface IP address there.
Its an DHCP client I thought it was an DHCP Server . Thanks
Nice that looks great. Is that antenna array home made?
its all homemade… but its only 1/4wave for 27mhz cb radio .havent tested it … my cb radio havent arrived i cant test it.
