Bandwidth Setting problem?
I had an issue with the Kraken Setting Software not processing information. In fact, it would pause the spectrum waterfall every time I transmitted on frequency with no antenna low power and would not give any DOA response. Other frequencies than the set frequency had no problem showing in the waterfall after I quit transmitting. I found the bandwidth set to 1264 Hz but when I set it to 5000 everything seems to work fine. I do not understand the issue was. Bill WB4LAI
Are you able to look at the spectrum when you transmit? It the signal directly in the active VFO bandwidth?
If it’s slightly out of the bandwidth, it could drop the surrounding noise floor below the squelch level when it transmits.
