It occurs to me that due to the rapid phase changes around resonance, I should ask this question:
Considering ONLY the impedance presented to the ports of the SDR, should I tune for 50 ohms, or resonance, or some other point, and if the third option, then where?
For example, a simple whip for 146 MHz will be resonant with a particular length of whip, but very unlikely to be 50 ohms. A different length will present 50 ohms with some reactive component.
Another question comes to mind: How (is?) the kraken protected from ESD on the antenna ports? A rolling vehicle can accumulate 6 to 10kV easily relative to ground, and brushing low foliage will present that charge to the antenna(s) that make contact.
