Have a somewhat maybe strange question. Dont know how to describe it, but i try…hope its possible to understand…
Is it possible to easy in the code add more than one “Array offset”?? We are in experiment stage with an antenna solution, and so far it looks promising. But we need to have at least 4 to 5 different Array offset, depending on frequency band (frequency) in use. So my question is…possible in an easy way to add writeble boxes with low and high frequency, and if key in a frequency inside the low/high limit, we get another “Array offset”. Does this make sence? for example…if i key in 100 MHz as low, and 200 MHz as high. And offset +5 deg. Then if i key in a frequency inside this low/high limit, the offset will be +5 deg. But if key in lets say 250 MHz, its another limit range, and KrakenSdr take that “array offset”.
Do you mean that you are creating a stacked antenna array with multiple radii, and each stacked radii is slightly offset from the other?
So you need the ability to have multiple preset offsets that trigger at different frequency ranges?
Yes, that is 100% correct, that trigger on user defined FQ ranges.
Is this something that is possible to do?
Yep this should be possible. I will add it to the list of features to implement in the next development cycle.
OK, sounds great, hope it will be soon and not several months. We are in the stage to mount on a high buildning. But we wait for final test
Br
Patrik
from mobile
Den lör 26 apr. 2025 03:18Carl via KrakenSDR Forum <thekraken@forum.krakenrf.com> skrev:
