Hello,
I am using a static config on a vehicle (tracking a source that does not transmit but every 30-90 mins) and set my location and heading in the kraken settings (not in app).
Kraken settings changed from GPS to static and a lat/long/heading are saved.
Seems the lat and long always look right on the map, but the heading (red line) is almost always pointing a good 30-45 degrees off. I confirmed the heading with 3 difference sources to be sure the heading I enter is correct.
Should the map heading line (red line) be correctly pointed while in static mode?
No issue when in GPS mode and moving, it always seems correct then.
