Is it just me? I had no trouble using V1 but I’ve run out of things to try and get useable doa readings from V2 beta. I did find a bad antenna cable with my swr meter but in dfing my local noaa station the doa always comes back in roughly the same quadrant no matter which direction the vehicle is moving.
Is anybody successfully using V2 IN A VEHICLE ON THE ROAD?
NOAA is our 24/7 continuous weather broadcast so it’s good for initial testing . On my photo it’s the east most red marker. Note the lines above the highway are while moving towards the station, the ones below are while moving away. They are not 180 degrees apart so something else is going on. It’s far enough away to be weak in some spots. I noticed no difference with squelch enabled or not but the audio remains understandable . I just started testing a new Doppler (N0EX) in the same area with no issues so far.
I’m having a problem where the app is reporting there’s no data from v2 pi and I’ve yet to get everything setup up stationary so I can troubleshoot what’s happening on the pi. It may be the signal isn’t breaking the squelch but that shouldn’t be the case as I too am going toward a known NOAA continuous transmitter.
I’m not sure if it’s the same as V1, but unless your location is static, at low speed doa stopped. I think the current android app blinks the strength ellipse to indicate the stopped reporting mode.
By the way, at about 4 km/h my GPS seems to give quite accurate headings towards the direction I walk.
I have seen somewhere a 7 km/h limit. I suggest reconsidering it or making it optional and configurable.
In spite of these minor bugs, this new piece of software seems quite good. Today I have further tested the scanning features, it seems it is what I was looking for.
Does the CTCSS tone ID work when saving to CSV? I could not get it working. Does it require the new mobile app?
I prefer not to install the new mobile app at the moment if possible.
