I have modified the heimdall software as indicated for the krakensdr gnuradio Correlation Check (rtlsdr_set_bias_tee_gpio(rtl_rec->dev, 0, 1);) so that the noise source is always enabled.
Looking at the basic block diagram of the system, it looks like the noise source is switched in before the R820T2 tuner, so any mixing or gain settings should be applied to the noise signal path. However, when I adjust the gain settings via the gnuradio block or the radio direction finding web page and look at the spectrum, it doesn’t look like the noise power changes at all.
What am I missing?
