I’m looking to use the KrakenSDR to measure and log the maximum power level seen at particular points around a box. Record those levels. And then do it again at various intervals I am very novice at this so I’m wondering if I can use the Kraken for this? The form factor is extremely appealing for me.
Around a box, as in a small box object? Kraken’s mapping system is designed to be used over a larger area.
If you’re just looking to measure and log power around a box object, you probably just need an RTL-SDR and a EM probe.
